i have a nasty vibration at 60/70 mph. I jacked up the front end and I think i have way to much play in the steering. the play is equal on both left and right tires. Since it is the same on both tires I have to assume the rack and pinion is loose since all the linkage seems tight and isn't moving. Does this seem reasonable and how can i get in there and tighten things up?
thanks,
dan
thanks,
dan
