vibration at freeway speed - free play in rack/pinion
  • vibration at freeway speed - free play in rack/pinion
    i have a nasty vibration at 60/70 mph. I jacked up the front end and I think i have way to much play in the steering. the play is equal on both left and right tires. Since it is the same on both tires I have to assume the rack and pinion is loose since all the linkage seems tight and isn't moving. Does this seem reasonable and how can i get in there and tighten things up?
    thanks,
    dan
    hmm.. after getting both wheels off the ground at the same time the problem seems very obviously to be lower ball joints. Interesting how I didn't notice that until both tires were off the ground.
    is it dangerous to drive with bad lower ball joints? I'm making a 4 hour drive tomorrow.
    thanks,
    dan
      thanks,
      dan[/quote] are your loved ones recipients of your life insurance? please drive something else or repair it first .
      91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
      93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
      1981 ford F-100 400000+ miles ? , looks rough - runs good
      1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
        There have been a number of people here that have a accident or damage to their car from bad ball joints that have came apart !!
        HD2500 Duramax Chevy
        Z28 LS1 power 500 +
          well i made it back alive on windy mountain roads and highway driving at 80 for 8 hours round trip so i guess i'm feeling pretty good to be alive.
          thing shook like a mo-fo though. will get them replaced right away now.
            Could be a bad tire too! Tires always seem to vibrate right around that speed when they are out of balance or have a broken belt.
            93 GL modyfied!!!
            :fish:
              nah, it's definitely balljoints. i can wiggle those wheels around quite a bit!
                OK, it was just a thought.
                93 GL modyfied!!!
                :fish:
                  i had a rack-n-pinion that was wore out on the drivers side and it shook some too.
                    thats actually a possibility too so i'm definitely going to check that out once i get the ball joints replaced.
