Cant get the Festiva to start!!!
  • Cant get the Festiva to start!!!
    Just got a festiva for free, been working on it but can't get it started. Thought it had a bad fuel pump but it is still good just not getting any power so I wired it to the lights! It has spark air and is now getting fuel all the way up to the fuel rail but I don't think the injectors are working or just not letting fuel through. Spark plugs are dry as a bone, no fuel getting in the cylinder s. Any advice would be appreciated.
    Try starting fluid.
    Check your fusible links In the engine bay. Fuel pump is triggered by the air flow meter. Except when priming at the turn of the key.
    The injectors are ran off the distributor.
    1989 Ford Mustang GT 5.slow
    1996 Ford F-150
      No power to the fuel pump suggests that it is possible you also have no power to the Ecm. No power at the ecm =no signal to open the injectors.... Look around here for the wiring diagram for your Festiva..... Trace the wiring with a multi meter to the blown fuse or broken wire and repair that and you should have a running engine..... Once that is done attach the fuel pump wiring back to the OEM location and you should have a functional beginning. Good luck.
        IT will run if you spray starting fluid in there. Ill check and make sure the VAF isnt stuck. and where is ECM located?
          The ecm is behind the drivers dash speaker. You will want the diagram and a tester to verify your wiring.
            How long has it sat?
            1996 Ford F-150
              10 years! Ive drained the tank, put a new fuel pump and filter, new plugs also and cleaned throttle body it was all gunked up.
                When u turn the key on try to feel the injectors to see if it clicks. Probably need 2 people. Sounds like your problem. They can be redneck cleaned to get it running if you look online for examples. Need some fuel line and a battery and some gas and compressor.
                1996 Ford F-150
                  ha ha sounds like too much trouble, ill just buy some new ones if i have too. and just checked the VAF and it was fine.
                    and it has one of those paint jobs that change color!!!
                      Pics or it didn't happen
                      1996 Ford F-150
                        file:///var/folders/iB/iB-rUdr9HnSRJZ9ogCEHSE+++TI/-Tmp-/com.apple.PhotoBooth-T0x1001179b0.tmp.EkPfl0/Photo%20on%202015-09-21%20at%2015.27.jpg
                            kind of hard to tell but it changes from green to purple to blue depending on what angle you are looking at it
                              Really sweet!
                              1996 Ford F-150
