Leaking coolant from between engine and tranny ?
  • Leaking coolant from between engine and tranny ?
    Today I saw a pool of coolant and it looks to be from the area between engine and auto tranny ?
    No idea what to do or where to start ..
    Thermostat Housing gasket?
    It would drip down where the engine and trans meet.
    Fallow the top radiator hose to the engine and check there for leaks.
      after further inspection it looks like the plug in block heater ??
        If the plug was pushed out by ice, then tap it back and make sure your antifreeze mix is 60:40 propylene glycol to water. You should be good to -48ºC
        If it's got a rust hole, change the frost plug and also check your mixture. Add glycol, circulate, hydrometer test. Repeat until you have a specific gravity of 1.046 at 15ºC.
          That's some serious effort.
          Glug Glug water.
          Glug Glug antifreeze.
          Glug Glug water.
          Glug Glug Glug antifreeze.
          Done.
          No issues past 30 years.
          Sent from my s-off'ed m7 with cm11!
            Glug Glug water.
            Glug Glug water.
            Done.
            Thats awesome.....love the glug glug......to the point. LOL
            92 GL, 98k
            77 Chevy shortbed
              jason, it is unbelievable cold in Yorkton in the winter.
                Jason is probably from down south or something...lol
                91GL BP/F3A with boost
                  So Glug more antifreeze.
                  I've never mixed it with such precision and measuring like rocket fuel.
                    non aqueous coolant
                    I could add a bull horn where the overflow tank is!
