If the plug was pushed out by ice, then tap it back and make sure your antifreeze mix is 60:40 propylene glycol to water. You should be good to -48ºC
If it's got a rust hole, change the frost plug and also check your mixture. Add glycol, circulate, hydrometer test. Repeat until you have a specific gravity of 1.046 at 15ºC.
