I started a thread yesterday "1990 Festiva doesn't start consistently and stalls while driving slow occasionally". Took it to a garage today (actually, coasted into their driveway) and they are thinking it's the ignition switch. They couldn't find a replacement. I stopped by Napa on my way home (got a ride with a friend). Napa googled the part and found a possible replacement, but I hesitated to get it until I checked with you Festy experts, first. I am near Salem, Oregon - fyi. The Napa part is a KS6664, was supposedly cross-referenced from a part number 1676420. Does anybody have other parts to cross-reference, that you know will be the correct part? Thanks much.
Can't find Ignition Switch for 1990 Festiva, need compatibles & firm Cross-Reference
What car is the cross-referenced switch for? I'm thinking that 1986-89 323 switches may be the same, since I can open a gen1 323 driver's door with my Festy keys.
Edit: they are apparently not the same. Checked on Rock Auto,and the 323 switch does not come up as a part for the Festiva.Last edited by TominMO; 01-11-2016, 07:56 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Are you talking about the key ignition turn lock cylinder to start the car? - - My key cylinder pins we're holding the key in and although it would start the car the key could loosely fall out. Today when putting the key in the ignition to start the car there are no engaging pins and the key feels that it's going into an empty hole. - - I went to autozone.com and matched the ignition lock cylinders for a 1990, same year, Mazda Miata and 323. They are LC14890 for automatic transmission at $20.99 and LA3421 for manual transmission for $269.99. I have 1990 stick shift Festy - - what's right???Last edited by meyek91974; 03-09-2016, 10:14 AM.
The automatic transmission has an extra wire on it, some sort of safety switch, probably similar to the one the manual has on the clutch pedal to keep from starting the car in gear. Given those prices it would be nice if they are interchangeable and manual's just don't connect the wire.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
According to your part numbers, the manual is quite a bit different
Manual
Auto
Rick
1993 Ford Festiva
2000 Ford E350
Originally posted by meyek91974 View PostVery different and I cannot find an inexpensive manual lock cylinder. It seems cheaper for me to take my lock cylinder to a locksmith as I cannot find a manual lock cylinder under $300 with tax included
This is a complete set for your ignition, both doors and the hatch.
Not sure if they still have them in stock at foregreen but you might check..
Shipping to me via Korea post (3 to 4 weeks) is 24.33 + $57.86 for the parts.
I know I ordered one for sketchman a couple of years ago. you might check with him to make sure it fit OK.
Neither one of the ones show in the pictures posted by eaglefreek look like my manual or my automatic.Last edited by 1990new; 03-11-2016, 05:08 PM.
Originally posted by Eaglefreek View PostAccording to your part numbers, the manual is quite a bit different
Manual
Auto
Ian
Sorry to bump this thread but does anyone know if the ignition turn lock cylinder from a carbureted car will directly replace an EFI car? I have to wiggle the key in my car a little bit for the blower fan and wipers to start working. Not a huge deal but I almost had one pulled today from a carbureted car but decided to hold off until I knew for sure it would work.1999 Toyota 4Runner - daily beater
1993 Ford Festiva - SOLD
1986 Toyota Cressida - #stressida hmmmmmm SOLD!!
