Starter Pinion not Retracting
  • #16
    Lesson leaned...the hard way. Now can I possibly remove the automatic transmission to reverse the flywheel without removing the engine. I hope so.
    • #17
      Yes! Remove pass axle nut. Slip driver axle from knuckle. Drop the cross member with trans attached. Remove trans, engine stays in and leans on the pass frame rail.
      There's more to it but you know those bits.
      • #18
        I find it easier to pull the engine on the auto cars . Leave trans as is where is .
        New build on the way .
        • #19
          I've change engines and transmission several times with 5 speeds but this is my first automatic.
          Great to hear that I can leave the axles in the transmission.
          An expensive lesson learned, burned up a good starter and had to buy a rebuilt one.
          • #20
            I hate the thought of pulling the entire assembly out again.. I'm going to attempt just the transmission removal this time.
            At least everything is clean this time so it should not take me too long.
            • #21
              I did get the transmission out and the flexplate removed and turned around.
              Ran into some difficulty trying to get the transmission lined up and bolted back to the motor.
              Jacking it up is just not working. Looks like I'm going to need my neighbors cherry picker again.
