I have been having a hard time with the car starting. It will turn over but not start. Started a few days ago. This past Friday on the way home I started to hear an exhaust leak. I started it up Saturday to go to work. Hard time, cranked forever but started but this time the exhaust was loud. I didn't make the connection. I try and start it Saturday after work, won't start just cranks. I put a starter in, dumb move, I did do lots of checks on batter and connections but still should of just took the old one off and had it checked. Anyway, last night I figure I would check the oil cuz I do have a slow lose of oil but not real bad. I check and the stick is bone dry!!! What the?? So today I check my compression and I get 180, 90, 90, 180. Not good. This is the same festiva I reringed back 18 months ago and found the cylinders to be scored and way bigger than specs. I threw it back together back then and just decided to drive her tell she dies, well I think that time has come. Anyone have a dependable festiva for sate?
Well, I believe its time for my 5th festiva...compression...
Swap in a B6 and call it a day.
You have better compression than Skippy right now: 150, >60, 90, 90. He still runs like a champ, just down on power. I'd say something weird going on here with those numbers. The engine should still start.Trees aren't kind to me...
Update: Well, today it was kinda nice here in Michigan so I try one more time to start my 93 festiva. The battery was pretty dead and it wouldn't do much. I decide to try and jump the thing with my new 88 festiva and it turned over quicker than ever. WHAT THE HELL?!??!?! I tried jumping it with my wife's car and all it did was turn over. Now today before I tried to jump it all I did different was take out the 3 main fuses. Pink, green, pink and put em back in, now I don't know if this was the magic trick to have it finally turn over OR that it is above freezing out and maybe I had a frozen gas line???? What do you folks think? STRANGE. Bought a new festiva for nothing.
Fuel won't freeze until you're under -20*F, so you can rule that out unless you have a butt load of water in the tank.
Now, when you say "turn over", do you mean crank or actually fire and run?Trees aren't kind to me...
Gas line antifreezes come in a variety of formulations, from methanol, to ethanol, to isopropyl alcohol, or combos thereof.
Here's a couple of answers.
It would just crank. It had to have been when I unplugged the fuses and plugged them back in its the only thing I did different from the other times trying to start her.Originally posted by FestYboy View PostFuel won't freeze until you're under -20*F, so you can rule that out unless you have a butt load of water in the tank.
OK so now check that the fuel pump roll over switch isn't tripped and then verify spark.Trees aren't kind to me...
