Recently I was doing some work and put the battery in backwards and had a bit of smoke come from the wires behind the coolant tank am I screwed or what exactly do I need to do because the car is no longer getting any power even when hooked to a jumper20161210_144018.jpg20161210_144018.jpg the center wire is what smoked before car no longer would get power
How screwed am i
Sounds like you fried the main fusible link
Just replace it with a cartridge fuse and you should be good to go again
Usually doing that takes out the ECU... But the only way to figure it out is replace the fuse links with PAL long leg fuses: 2 pink and one green.Trees aren't kind to me...
This. Make sure to get the long leg cartridge fuse. Like this http://www.oreillyauto.com/site/c/de...1175&ppt=C0172 You can get them from cars in the junkyard if you are not in a hurry.Originally posted by Damkid View PostSounds like you fried the main fusible link
They are basically just a wire with connectors on each end. Carefully pull on each end of the link to remove them. They may take some effort to get out if they've never been removed before. Reverse for installation, unless you buy fuses, which makes it even simpler.
Needle nose pliers would probably make the process easierLast edited by TWFodor; 12-19-2016, 09:43 AM.1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
1991 GL - B6d, g-series trans, aspire brakes, Advanced Suspension coilovers, Miata 7 spoke rims, '98 Prelude seats, more to come!
2005 Focus ZX4 SES - purchased from original owner, my grandmother. Currently my wife's daily. 210k
You can follow me on instagram @twfodor
