Well.. I double checked the tps. It was still a tad off adjusted that with not much change.. Put in New ect sensor...fixed. Idles great and runs great! Thanks everyone! Now just to replace wheel bearings and water pump and timing belt... And figure out why the heck this thing is so unstable on ice.. Any tiny bit of ice on the road and the back end seems to dart all over the place.. It's bad
91 Festiva high/strange idle when warn
Replace the rear struts.Trees aren't kind to me...
Well I spoke too soon on the idle... It seems to not be nearly as bad but it's still random.. Sometimes it's perfect sometimes it's high, sometimes it bounces up and down (sounds like a rev limiter but at idle).
Edit: its very random... It was high idling this morning, then I stopped to get cup of coffee, so I shut off the car. When I came back to leave I started it and then it was idling fine and idled perfect the rest of the drive, that was only a few minutes of driving and idling...Last edited by Dodgeih; 01-30-2017, 08:54 AM.
Get the engine hot, disconnect the IAC and adjust the base idle screw if there's anything left in its travel.Trees aren't kind to me...
No!!! No no no... There's a base idle air bleed screw at the front right of the throttle body.
Don't touch the throttle stop...Trees aren't kind to me...
Then you can run into the plate getting stuck in the bore of the TB. There's another option, and that's plug the inlet pipe to the IAC. This forces the idle to come from the TB only. Use this method to test for other air leaks in the system. Also, for it to work properly, you must also plug the fresh air bung on the intake tube so the VAF doesn't have a fit while the engine is running. If all is well, the base idle bleed screw should have to come back out over a full turn from it's current position.Trees aren't kind to me...
Other than poor idle and engine response when cold, nothing. Once it's warm, things should be normal.Trees aren't kind to me...
