2nd gen was available as 8v and 16v sohc and 16v dohc.
The 90-94 323 was second gen 8v, the tracer only got the 1st gen 8v.
I'll get a hydrometer and check the coolant once a month. I recommend ALWAYS using anti-sieze when putting spark plugs in aluminum heads. Good to know on the NGK regap, thanks. Btw, for the break-in procedure, guidelines vary between manufacturers. How harsh should I be on this engine? Half throttle, rev up to 4k, accelerate and decelerate frequently for about 500 miles?
