Originally posted by TominMO
Newbie help, parking break not engaging enough to actually park.
Well you know what Assuming does Tom!Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
So I adjusted the break as much as I could with a box wrench. It didn't tension enough and I can still pull the Ebreak all the way to the top with no tension at the top. I'm guessing I'm going to have to pull the drums to adjust it from this point.
Think I would do much damage leaving it in first when I park for a week or so until I can fix the parking break?
A lot less force than if you were flooring it in first. Or spinning and hopping the wheels. Or even lightly accellerating now that i think of it.Originally posted by Dalton12 View PostOnly reason I was worried is because ALL the weight is on the first gear and none is on the break.
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 06-13-2017, 12:37 AM.
Make sure the cable is intact from the drum to the equalizer. If it's broken, it can be repaired on the cheap. The actuator arm inside the drum needs to be sloppy loose once you free it up, and lubed once a year at minimum to keep it that way. Lube can be applied through one of the lug holes with a straw.Trees aren't kind to me...
Not sure yet, I have yet to actually get underneath and really check it out.Originally posted by denguy View PostRear brake adjuster frozen with rust ????
Alright thanks, I'm going to switch the wheels and adjust the breaks all at once.Originally posted by FestYboy View PostMake sure the cable is intact from the drum to the equalizer. If it's broken, it can be repaired on the cheap. The actuator arm inside the drum needs to be sloppy loose once you free it up, and lubed once a year at minimum to keep it that way. Lube can be applied through one of the lug holes with a straw.
