Control Arm / Stabilizer bar
  • Control Arm / Stabilizer bar
    I was trying to replace the control arm on my front left wheel, and I couldnt for the life of me get the darn stabilizer bar nut off. It seems to have rusted to the the stabilizer.
    Im guessing my only option is to replace the stabilizer bar too. I broke a socket wrench and a breaker bar adapter in the process, so it's on there pretty good. I did use a liberal amount of wd40 in the process to no avail.
    Any tips for avoiding replacement of the stabilizer bar?
    Thanks,
    Dan
    Froggy in the meadow, under the log. BIG JILM!
    did you remove the cotter pin first??????
      Yes, the bolt wont even budge, the threads that are exposed are eroded to just about nothing.
        Use a torch to heat it up. Get it red hot. If you don't have a torch then drive it to a shop and ask them to heat it up and get it loose.
          grab wd40, oil and old tooth brush an old pocket knife, scrape around the edge of it with the knife cleaning out the grooves. oil it, use liberal amounts. wipe it off with napkin hours later. wd40 the **** out of it and and then tooth brush it like crazy, bang on it with a wrench then u might be able to get it off. this is the cheap alternative.
          [EDIT] jeeze i have a torch and i didn't even bother to think of it
          didn't buy the torch for any kind of work at all :wink:
          1.3Liter 4 cylinder FI , OHC, FWD, 3DR, 4ST, Stud. Tires
            THanks loads. Any ideas where i can get a replacement stabilizer bar?
                Maybe here
                This website is for sale! festivamotorsport.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, festivamotorsport.com has it all. We hope you find what you are searching for!
                The torch will work. Not one of those propane torches, a real oxy/acetylene set.
                  Im gonna email them and see if they can get me one.
                  Thanks
                    dont email FMS!!!!!!!!!!!!!!!!!!!!!
                    use the phone instead !!!!!!!!!!!!!!!!!!!!!!
                      Thanks.
                      Its too late, am i doomed to a forsaken existence?
                        i'd try the most powerful impact wrench I could find and use a few cans of penetrating solvent
                        over a couple of days. i had an axle nut that had practically welded itself on, a 4 ft breaker bar
                        couldn't get it loose but 5 secs with a good wrench and good air supply ( 10 bucks at local
                        mechanic shop) and it popped right off.
                        Nothing says "triumph of enthusiasm over physics" like a Front Wheel Drive race car.
                        - Dennis Grant
                        FarNorthRacing.com
                          Why do you need a replacement,did you break it?
                          Renegade-Midwest Festiva Inc.Illinois Chapter
                          99 Dodge Caravan SE
                          95 Taurus SHO auto 265hp
                          94 F150 351W auto (for sale)
                          95 Honda 1500 Goldwing SE
                          95 Iszuzu Trooper LS
                            Since your bolt is frozen on the stabilizer bar you should also check the bolt that mounts the arm to the body. It is common for them to sieze and that is a much more difficult problem.
                              I havent tried the other bolt yet, but im sure it will give me just as much trouble...
                              I did not break it, I was just looking for a replacement so I knew where to find one if it came down to it.
                              THanks for a ll the help guys.
