Ok, not a good week. When i crank the engine the rotor in the distributor dosent spin. I assume my timing belt broke? Also there is a knocking sound coming from the passenger side of the block when i crank it. Is the engine screwed?
Timeing belt??
Broken belt or broken cam.
Probably not if its turns over.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
sounds like a timing belt problem... its pretty easy to see if the timing belt is broken, just take loose a couple of screws at the top of the plastic timing belt cover and pull it back and you should be able to see down in there. I'm guessing that knocking sound is a broken timing belt flopping around inside the cover.No festiva for me ATM...
