Last week the automatic seatbelt was working. Today it is not. Where do I get it working again.
Help! Automatic Seatbelt stopped working.
Most likely the the control module, but here is the diagnostic procedures for everyone.
Key OFF.
Disconnect the passive restraint module connector.
Measure the voltage on the "Y" wire at the connector.
Is the voltage greater than 10 volts?
N? Service the Y wire
Y?
Measure the voltage on the "BK/Y" wire at the connector.
³ CONDITION ³ VOLTAGE ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ Key OFF ³ 0V ³
³ Key ON ³ Above 10V ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
Are the voltages within specifications?
N? Service the BK/Y wire
Y?
Key OFF.
Measure the resistance of the "BK" wires at pin M/N of the connector to ground.
Is the resistance less than 5 ohms?
N? Service the BK wire.
Y?
Locate the inertia switch.
Measure the resistance of the "GN/W" wire at the inertia switch connector to ground in the following conditions:
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ CONDITION ³ RESISTANCE ³
³ Open ³ Greater than 10,000 ohms ³
³ (tripped Ä switch not depressed) ³ ³
³ Closed (set Ä switch depressed) ³ Less than 5 ohms ³
Are the resistances within specifications?
N? REPLACE the inertia switch.
Y?
Measure the resistance of the "R" wire between the passive restraint module and inertia switch.
N?Service the R wire
Y?
Locate the driver's and passenger's door switch connectors.
Measure the resistance of the "BK" wire at the connector in the respective door to ground.
Are the resistances less than 5 ohms?
N?SERVICE the "BK" wire in question.
Y?
Measure the resistance on the "LG/R" (driver's side door) and the "LG/R" (passenger's side door) at the connector to ground.
³ Door open ³ Less than 5 ohms ³
³ Door closed ³ Greater than 10,000 ohms ³
N?REPLACE the door latch assembly.
Y?
Disconnect the passive restraint module connectors and both door switch connectors.
Measure the resistance of the following wires between the door switch and the module.
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ LH door switch "LG/R" and module "LG/R" ³ less than 5 ohms ³
³ RH door switch "LG/R" and module "BL/O" ³ less than 5 ohms ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
N?SERVICE the wire in question.
Y?
Locate the A-pillar limit switches (driver and passenger side).
Measure the resistance of the "BK" wires to ground.
Y?
Open door.
Measure the voltage on the "Y/BL" (driver's side) and the "BL/BK" (passenger's side) at the limit switch connector.
³ POSITION ³ VOLTAGE ³
³ Belt in motion toward A-pillar ³ Above 10V ³
³ Everywhere else ³ 0V ³
N?REPLACE the A-pillar limit switch in question.
Y?
Locate the B-pillar limit switches (driver's and passenger's side).
Y?
Door open, belt in A-pillar position.
Key ON, close door.
Measure the voltage on the "Y/R" (driver's side) and the "W" (passenger's side) at the limit switch connector.
³ Belt in B-pillar position ³ 0V ³
³ Everywhere else ³ Above 4.5V ³
N?REPLACE the track and motor assembly in question.
Y?
Key ON, door open.
Disconnect the passive restraint motor connector.
Ground the "BK/R" (U) (driver's side) or the "Y/GN" (A) (passenger's side) wire at the motor connector.
Apply 12 volts to either the "BL/GN" (V) (driver's side) or the "W/BK" (B) (passenger's side) wire at the connector.
Does the belt move from pillar A to pillar B?
Reverse the power and ground leads.
Does the belt move from pillar B to pillar A?
N?REPLACE the track and motor assembly.
Y?
Key OFF.
Disconnect the passive restraint module connectors.
Measure the resistance of the following wires between the module and the motor.
³ Driver Side Connector ³ Passenger Side Connector ³
³ "BL/GN" (V) ³ "Y/GN" (A) ³
³ "BK/R" (U) ³ "W/BK" (B) ³
N?SERVICE the wire(s) in question.
Y?REPLACE the passive restraint module.
Just looking at that troubleshooting procedure alone is enough for me to put in regular seatbelts!!
i still and always will prefer my manual seatbelts :lol:
but i did learn something recently which i think is neat, as i was comin accross the border bringing a festiva home that i bought from Logan, canada does not allow any car to be made or brought into canada that has automatic seatbelts (so i kept quiet about the auto belts in the car we were bringing accross) so obviously this law must be fairly old, and obviously it explains why until i went to the states i had never seen a festy with auto seatbelts
Old thread for you Monsoon.
I bought a 90 Festiva today for a friend and the driver's side auto belt does not work. The passenger side works.
I can hear clicking, like a relay, when the driver's door is open and closed, but nothing out of the motor. I've removed the panel and checked connections and the motor is getting power. Can these units be serviced or easily replaced?
Also, what is the plastic thing with lines running to it inside the driver's side rear near the fuel filler?~Austin
Red 88 L (Ocho)
The motors are clear down near the bottom, if that's what you're talking about. Mine are blue.
What? But the Festy's in Canada had to be equipped with "Daytime" headlites?Originally posted by Damkid View Posti still and always will prefer my manual seatbelts :lol:
but i did learn something recently which i think is neat, as i was comin accross the border bringing a festiva home that i bought from Logan, canada does not allow any car to be made or brought into canada that has automatic seatbelts (so i kept quiet about the auto belts in the car we were bringing accross) so obviously this law must be fairly old, and obviously it explains why until i went to the states i had never seen a festy with auto seatbeltsSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Welcome to the forum Dude. Please add your city to your info. That way we can pick on you for taking the the "Tiva" name to a new level !:p Just messing with Bro-Welcome!Originally posted by Flametiva View PostLast week the automatic seatbelt was working. Today it is not. Where do I get it working again.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
WOW ! This totally sounds like my Supervisor at work ! AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAOriginally posted by ;75347Most likely the the control module, but here is the diagnostic procedures for everyone.
Key OFF.
Y?
³ Key OFF ³ 0V ³
Y?
Key OFF.
Y?
Y?
Y?
Y?
Y?
Y?
Y?
Open door.
Y?
Y?
Key ON, close door.
Y?
Key ON, door open.
Y?
Key OFF.
UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUMMMMMMMMMMMMMMMMMMMMMMM
AAAAAAAAAAAAAAAAAAAAAAAAAAA UUUUUUUUUMMMMMMMMM
Maybe he's been reading these test procedures also????
