just drop the tranny. its not heavy and you dont need a hoist to get it out. i just jacked the front of my car up about 2 feet and put stands under it and went to work. i held the tranny while a friend undid the bolts and i let it rest on my chest and crawled out. just be sure to support the engine with a jack and wood under the oil pan!
changing the clutch
you need about 1 1/2 ft clearance to make it real easy but 1 ft will do you just gotta move the tranny a
bit more to squeeze it out. Use a pair of jackstands. Lift one side then the other back and forth till you
get enough height. If you don't have a engine lift just do the tranny only method, as you can lift it back in
by yourself.Nothing says "triumph of enthusiasm over physics" like a Front Wheel Drive race car.
- Dennis Grant
FarNorthRacing.com
If you drop the tranny only, be sure to remove the stupid plastic guard thing. It'll come out fine without removing it, but when you're bench-pressing it back in and a piece of plastic gets in your way you'll wish you had taken an extra minute before hand.Any difference that makes no difference is no difference.
