not festiva but new project wife and i are doing
  • #46
    Originally posted by ohsoslow View Post
    my first big block set was home built. using opposite side shorty headers (this is far from ideal) at the time my welding and fabricating skills were not what they are now. i hacked them off and bought a ton of mandrel bends from the speedshop (most bends were messups) i mixed and matched and bent to make the collecters turn forward twords the radiator and up to a merge pipe to were the batt once was.
    kinda waht i was wanting to do.
    1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
    1993 BBF 466cid mustang notch 7.7 ltre
    festiva turbo b18 project
    2001 BMW 325i
    1996 ford F-150 sold
    • #47
      heres a vid. non turbo stock 460. camera wouldnt focus to well. just took the car out to play for a few min before we headed out to eat.
      2001 BMW 325i
      • #48
        sounds mean!
        -Josh R
        • #49
          hey miz i'll do some digging and see if i can findthe pic's of the ones i built
          88 mustang 427 stroker garrett t-76 turbo best run 8.86@ 151.56
          91 red gl festiva the $50 daily driver <--toast
          WANTED 78-80 FORD FIESTA (PREF GHIA)
          • #50
            that would be great. any info is always welcome. tomorrow at 6 am im headed up Brian's "25horseplay" way. to pick up another 460. d1ve block. ill through it in my car while i build my c9ve motor.
            2001 BMW 325i
            • #51
              hey brian, just wanted to say thanks. it was a long trip but we made it back. tell dave ill tear into the motor the weekend comming and ill let him know about it. he wanted me to let him know if any problems with it. oh it was nice to meet the two of you.
              2001 BMW 325i
              • #52
                Great meeting you guys. I am glad you made it back OK.
                93 GL modyfied!!!
                :fish:
                • #53
                  well so far we have torn the heads and intake off. still havent looked in the oil pan yet. ill get to that soon though. i might have a fewmore pics of my car and another vid if i can find them.
                  2001 BMW 325i
                  • #54
                    quick update. i have the new 460 torn down ready to head to the machine shop. i have a list of parts i will be getting for it as well. not quite finished with the rundown of parts. i might end up changing a thing or 2 listed. i was on the phone with summit for about an hour going over my build and what im doing and this is what we came up with. with a few alternates. but heres the list as it stands right now.
                    rods- scat h beam 529.95 sca-66605
                    rod bearing 95.60 cb818hn
                    main bearing 61.95 ms1039v
                    pistons- trwl2443nf30 54.00 per 432.00 i found a differant set i may go with. fro around 600 for 8
                    rings- 100 a set slp-r1024635 file fit to match bore 141.00 i believe
                    cam- flat tappet cca-cl34-245-5 255.95
                    valve springs 924-16 105.88
                    cam bearings- sh1766s 48.39
                    main stud girtle 204.95 tfs-53400700 block machining required
                    rocker girtle 289.95 tfs-54400700
                    rocker 289.95 tfs-53400621
                    total 2414.57
                    without
                    heads-
                    intake-
                    4bolt main caps Milodon 11450 279.95
                    adjustable valve train Crane Cams 52655-16
                    2001 BMW 325i
                    • #55
                      This car will be awesome without a turbo!
                      93 GL modyfied!!!
                      :fish:
                      • #56
                        thats the nitrous motor build. the turbo build will have alot of the same parts differant pistons for lower compression, and BME rods rated to 1000hp . other than that pretty close to the same. the motor i am turboing is still in my car. and will take alot longer to build since i have to have alot of custom stuff made. like rods and pistons, and headers. but that is all still in the works. i posted the update with the nitrious parts because i pretty much and it set, might change a part of 2 but still pretty much all in stock parts from summit and about 5k cheapet to build the motor than the turbo.makes less power about 700-800 hp but should still be awesome. turbo motor should be around the 1k hp range.
                        my rods for the turbo should be around 1100.00 and pistons around 900 or so. but when i get them i shouldnt have to worry about breaking them. ill try and get some pics posted of the 460 we just tore down.
                        and i just noticed how many post you have brian.. 10.3k i think you need to get that posting number up a bit , it looks a little low.
                        2001 BMW 325i
                        • #57
                          Yea I'm a bit of an underacheiver!
                          93 GL modyfied!!!
                          :fish:
                          • #58
                            should be getting taxes back in the next week or 2.. so i should be ordering my pistons, rods and cam. should be fun.
                            2001 BMW 325i
                            • #59
                              Fox body notch backs have got to be the most beautiful cars ever designed. Awesome project!
                              Semper Fi til I die!
                              1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
                              • #60
                                thanks alot. its looks pretty good now.. but after the paint job and new wheels i think it will be alot better.
                                2001 BMW 325i
