Here are some pics of my new-to-me 1987 323LX. 145K miles.
This is the old airbox I just removed.....
...to install this.
Detail of the brackets used.
The funny thing is that I had all the stuff I needed to do this just laying around. MAF adaptor is from Rocketman BTW.
Car needs a disty o-ring, valve cover gasket, probably a cam seal. PS pump is leaking so I took the belt for it and the A/C off. Will try to re-seal the pump eventually; I bought a seal kit. Installed two new shifter bushings as well. Very minimal rust issues (trunk behind LR wheel, and under car), which have been taken care of.
Edits: found two dead mice in stock airbox.
Driver seat is actually in fine condition, under that cover. Just some wear on the fabric of the outside seat bolster, but no tearing.
I will be buying a dash cover. There is a place that still sells specific ones for the 323; it even asks if you have the dash clock or not! (It does.) http://www.autoanything.com/dash-mats/dash-designs-dashtex-custom-dashboard-cover
...to install this.
