actually now that ive got my motor swap, brake upgrades, and coil-overs done... im happy for now performancewise till the snow melts...
so thats why im working on the stereo and looks of the car now :wink: currently im working on some fiberglass for both across the back to replace the rear speaker panels and the rear deck with one removable FG piece...
now it wont be anything super fancy, but i plan on moving the components outward to where the old speaker locations were but tilting them up at an angle a bit to aim a little more towards the passengers and not the ceiling lol. the tweeters will be right along side them. now in the center though where the old regular decklid was at, will be a nice piece of plexiglass
so you can see down through to the trunk.
the trunk area with the pieces ive been working on, will accomodate 4 10" subwoofers, my regular battery (which had to be mounted back there anyways from the swap) and the aux. battery i will be adding in much like dj has done on techno.
im using the plastic panels from the sides of the trunk and molding my pieces directly to them and adding strength to weak spots, filled in the tail light acess area. there will be one 10" sub in each side panel aimed inwards toward eachother, the nice thing about using these panels is they will mount directly to the car as the backing is a stock piece! this will help with keeping everything solid and in place...
in the center of the trunk there will be a false back to the seats which my amps and crossovers for the component system will be mounted onto with wiring going back through for a clean install. in front of that is a false floor im working on which sits level with the edge the latch sits on. two more 10" subs will sit in this area with the two batteries sitting underneath in what used to be the spare tire area. (im cutting it out and welding in two seperate boxes for the batteries, cables will run up the back behind the amp wall and nobody will ever be able to see or have a clue where my batteries are even at :wink:
on top of it all though my main priority with it mounting in using mostly stock mounting points is i want it all to be easily removable for when i go to the track. the main floor will pull out, the side enclosures will come screw out like normal, and the amp rack will more than likely be just as easily removable...
so far all ive worked on is the floor and side speaker mounts, im waiting on some plate from work for the battery enclosures and anotehr set of 10" speaker rings for the floor area.
oh yeah and there will be neon lights in the underside of the decklid replacement which wil be hidden just to light everything up inside for some sweet looks
i havent quite decided on what type of 10" to go with yet, so far i have jsut one of the sony's left (the amp literally started the lower powered one one fire...) i guess thats what i get for running 1000w through a 400w sub lol. the sony is nice for laying out my pieces, but i dunno if i will go with 4 of them...
whats a good 10" for multiple sub setups?
so you can see down through to the trunk.the trunk area with the pieces ive been working on, will accomodate 4 10" subwoofers, my regular battery (which had to be mounted back there anyways from the swap) and the aux. battery i will be adding in much like dj has done on techno.
