ok on my 92 GL it has some what stock exhaust the cat has been removed and some patchy stuff has been put in place of it and it is leaking really bad! i was wondering if i put my bp exhaust on it would it be to much? it was on my red bp car and it stats with 2 inch then when it gets to about the e break handel it goes to a shorty cherry bomb that is 2 1/2 inch the rest of the way out and it goes out by the rear tire on the passenger side. will that be to much for it? will i lose to much back pressure? or it be ok and not lose to much? it has no cat.
exhaust
Even though you have me on your ignore list.:thebirdman: I will tell you that is probably too large for a stock B3.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
It's got to be better than patched up and leaking pipe. I'd run that. At least for now.Festiva: Because even my dog can build a Honda.
No problem Monsoon, I can fix that so he access to your info!
Monsoon says: "Even though you have me on your ignore list. I will tell you that is probably too large for a stock B3."
There that should help!'93 Blue 5spd 230K(down for clutch and overall maintanence)
An engine has to have a certian amount of back pressure to run properly. Thats probably why you can tell a difference in power. If youve got it , go with the 1 3/4.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
I figured if you read this thread and seen my reply youd have my back.Thanks! :thumbleft:Originally posted by Pu241 View PostNo problem Monsoon, I can fix that so he access to your info!
And yes now and then I try to be a little helpful.Last edited by MONSOON; 11-23-2009, 08:05 PM.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
From what I discerned from this thread, you should just get a test pipe made to go where your leaky, gutted cat is.
That or just get it welded up unless it's miserable. Got any pictures?-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
