G-series tranny swap
  • Could be what you were saying about the blocks that the pp sit on.
    I also haven't had the best luck with spec clutches. I now run an ACT.
    -Greg
    Redneck Engineer
    FOTY - '09
    • i looked up the clutch, it is rated for 309 ft*lbs in the escort gt
      here is a picture of the flywheel. it does look like they machined the blocks now that i look at it. hopefully they were to the right tolerances.
      i wonder if the clutch fork isnt fully returning to its original position because of the bolt binding or somethign like that.
      or maybe there is grease on the clutch? i cleaned it with brake parts cleaner but who knows. how long would this take to burn off?
      • i think im gonna drive with it for a little while and baby the clutch, see if a little break in period wont burn off any oil or help it stick better.
        can anyone reccommend a tranny fluid that will help get rid of grinds? like the pennzoil synchromesh or the gm synchromesh?
        • 3.4 qts. of mercon atf is what I'd run.
          -Greg
          Redneck Engineer
          FOTY - '09
          • Mercon atf is what it calls for. Most 323 guys run gl4 spec 75w90 though.
            Better Than Nothing Racing
            Way too many cars
            :woc:
            • Originally posted by shorestiva View Post
              gl4 is such a pain to find.
              i have dex/merc atf in it now.
              • i run 80/90 in mine but i think im gonna put in some 140 when i get the turbo on it...
                Mike, AKA the sasquatch
                • Go for the sychromesh.
                  91GL BP/F3A with boost
                  • Originally posted by bhazard View Post
                    speaking from experience? pennzoil or gm? i know some trannies that call for only gl4 can have issues if you use gl5.
                    • I tried 75/90 in mine and it seemed like it took a little more shift effort. I have been running walmart brand supertech (lol) dexIII. Much smoother. You def need to give your clutch time to break in/heat cycle so it will last a wile.
                      • i made this custom washer to help keep the bracket from binding. the clutch is a little smoother now.
                        • Originally posted by Ghost View Post
                          Yes big upgrade from dex /merc. I used the Pennzoil from advance. Its supposed to be the same as the GM flavor.
                          • anyone care to diagnose my tranny leak? it appears to be coming from the very endcap of the transmission... but why would that leak?
                            from underneath
                            from the front
                            completely dry up top and on the back side.
                            • It's just a few bolts to take that cover off. It probably just needs to be resealed. I've seen one leak from being dropped on the ground.
                              -Greg
                              Redneck Engineer
                              FOTY - '09
                              • if its leaking out of the seal... how is it crawling up the end of the tranny like that? i guess wind could do it
