Originally posted by bobbyspider
Turbocharging a B3
Stock festiva exhaust feeding the turbo ans 2.5 inch going back to the motor-Greg
Redneck Engineer
FOTY - '09
I need another turbo car....hmmmmm1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
I'd say T25...In love with a MadScientist!:thumbright:
You guys are really making me want a turbo b3!!! I've never had a turbo car so a b3 would probably be the best start!"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
i just got a t25 turbo, collecting the parts to turbo the b3=). t25turbo and flange also have an aspire manifold looking for a shop cheap around here to weld me the flange on the manifold. still need many to buy but all will be bought and installed by summer so i can take it to the tracks oh yea=) planning to run 10psi on the tracks and 6psi daily t cruise around
^ Dank, language? you know better....
can someone fix this please?Trees aren't kind to me...
That tdo4 is for a 2.0 liter 16 valve engine, if it came off a dsm then it's probably got a dsm type flange although they do make them with a t3 flange. I kinda looks like a t3 flange, but turned sideways. I want to say the 1st gen tdo4 cars (automatics) had 370cc injectors and the tdo5 cars (5 speeds) had 440cc injectors. I think that will be too much turbo for the b3 imo, consider something found on like sized engines for more street ability.Originally posted by DankBuds420 View PostWell I think I found the turbo Im gonna use, a TD04-13g. I havent taken it off the car yet, Im just piecing everything together still. I think its a T3 flange? Does anyone know for sure? Would the 1g DSM injectors work in my B3 fuel rail once I turbo it? Thanks for the replies...
I run a KKK K03 on my 1.6 liter (8 valve)...it was sized to a 1.8 liter (20 valve Audi) engine.
I get boost at 2,500 rpms
vj11 came on a 2.2 and was perfect on my b3. It spooled very fast. Remember, just about all factory turbo cars came with an undersized turbo for low end pep so dont base a turbo choice on what size engine it came on from the factory.
dank- run some dsm injectors with the festiva ecu and you will get the same mpg as those bigger engined cars.
I got 22 mpg and 10:1 - 10.5:1 afr's cruising with bp injectors in the b3 w/ vj11. was enough fuel for 12-13:1 afr at 15psi.Last edited by resuwrecked; 03-22-2011, 10:06 AM.
I'm so torn now. I wanted a frankenB so bad, but throwing a turbo on a stock rebuilt B3 sounds like a nice idea. Grrr.
