Turbocharging a B3
hey guys,
im looking at doing the exact same thing (turboing my b3)
im not doing for huge power gains, itll be more to keep up with traffic without having to thrash the piss out off it.
Ive done a lot of work with b6/bpt/bpd conversions in 4wd ke tx3 lasers etc and got a ton of parts left over from the tx3
plan is to bolt on a t25 (from an r32 gtr) and see what happens. Im keeping the stock zorst as i dont want it over boosting etc.
the festi is my daily work lappo car so im not gonna spend too much on and most of the gear will be fabricated by me!
steve
keep us postedTrees aren't kind to me...
Well, for a T25, that's about $40 cheaper than most, if not more. That's what I'm going to use when I (finally) find a Festiva and turbo the B3.1990 White L-Plus 5-speed rust-machine
Scrapped
1991 Blue L 5-speed
daily driver, intermittent project
1993 rustless wonder
A shell, awaiting suspension, brakes, and B6T
What kind of gains would a T25 add to a B3 if it were mounted under the hood, with an intercooler from, say, a VW New Beetle Turbo S?In love with a MadScientist!:thumbright:
Personally I have found that bigger turbo are better for engine reliability. The reason being that they produce MUCH less heat at the same boost level. Which in turn allows less likelyhood of knock the ability to make more power on less boost.Originally posted by iceracerdude View PostRemember, just about all factory b3 engines have cast pistons, stock non-moly rings, and higher than turbo friendly compression ratio's! lol right!
Get a smaller turbo unless you want your engine to more closely resemble Afganstan's economy.
I switched from a 60trim t3 to a garrett gt3076r on my element and gained almost 100hp on the same boost level. Fuel economy and reliability were unchanged.
if you mean honda element.Originally posted by rollertoaster View PostPersonally I have found that bigger turbo are better for engine reliability. The reason being that they produce MUCH less heat at the same boost level. Which in turn allows less likelyhood of knock the ability to make more power on less boost.
you sir... are the man.
most road race cars have huger turbo and run lower psi for that reason exactly.
You're making my point, a KO3 on a 1.3 8 valve IS a big huffer! I recommended it because It's designed for 1.8 liter 20 valve (strengthened) engines.Originally posted by rollertoaster View PostPersonally I have found that bigger turbo are better for engine reliability. The reason being that they produce MUCH less heat at the same boost level. Which in turn allows less likelyhood of knock the ability to make more power on less boost.
As if there's no such thing as too big?
I tried PMing resuwrecked but his mail has exceeded capacity, so...Originally posted by resuwrecked View PostMine spools faster:geek:
I t-charged my first festiva with the b3 and my current car before i did the bp swap. Like greg, i had the most fun with the b3t. i used an aspire manifold and a vj-11 with a 12:1 fmu, walbro 255 intank and the msd btm (not necessary but can get more power with more advanced base timing). The thing was a rocket with just 8psi.
I want to turbo my B3 and your setup looks appealing to me. I was hoping you could answer a few questions for me. I was originally planning on running a vj14, which I am under the impression that it is smaller than a vj11 and will spool sooner. At what rpm range did your vj11 spool? This may be a newb question, but how did you limit your boost to 8psi? I want my B3 to retain its reliability.
I'd appreciate your input and Happy Holidays!
Thanks,
WillI know how to use the search function, I just don't always choose to use it. New modifications, solutions, and information are discovered every day and I want to know what the current concensus is for whatever topic I have in mind. Thank you for understanding this!
