Finish your shift fork actuator
E-Series disassembly/reassembly thread
my donor case, a four speed that didnt go into fourth gear. Found out the reason why it didnt go into fourth was because a bearing was worn out. So now i have a spare four speed. The cases are near similar except the four speed has a different location for one of the sensors.Last edited by Ford Fester; 01-17-2012, 01:49 PM.Ford Fester
After i painted it. I went with a gunmetal color. I didnt like plain gray, mexichrome or black. Biggest thing is just take your time and it should go together easy. I did no hammering other than to remove and install the shift shaft/fork pins. Case halfs should come apart and go together easy, you can almost install them without touching anything until they meet.Ford Fester
Hey man, where's my POPCORN!?
extra butter!
Very nice write up btw, even without popcorn =/2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Awesome write up fester, bozzo button for you!!!!1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
Very very nice!! I have to try this some day. After my 1st engine rebuild, I suppose.
Much thanks to Ford Fester (and Ice Racer) for the pics and instructions.
