I recently purchased another B6 to replace my bottom end. I would like to run some forged pistons to withstand the turbo easier. Who makes forged pistons for the sohc B6 8v?
B6 piston options
B6 piston options
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pigTags: None
I wonder if they might not be the same pistons for the B6D or the gen 1 Miata.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Nope, they have 3 valve reliefs. Not 4.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Correct, but I wonder if they couldn't be made to work, or maybe even work as is? It may be worth getting ahold of a used one to play with (unless you already have). PTV may be OK with factory cam, or, you could have them notched (not uncommon). Compression height and dish may be different as well....who knows what the end result would be, but it might be worth checking out?Originally posted by gauge_half_inch View PostNope, they have 3 valve reliefs. Not 4.Last edited by blkfordsedan; 04-13-2012, 04:22 PM.Brian
For the same reason I didn't buy a Honduuh. Why be like everyone else? Plus I've already boosted the one i have in the car,but my rings didn't hold up to the boost.Originally posted by Grey Vw View PostWhy not just get a b6t?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Bump, anything?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Forged pistons will not make much difference on ring life. Oil cooling, oil quality
and a oil jet aimed at the bottom of the piston will make a difference. If you had
a hole in the piston or a broken skirt, Forged will help you there. Forged may actually
be harder on rings because of the sloppy fit required.Reflex paint by Langeman...Lifted...Tow Rig
I'm sure several places would custom make some, but I doubt it would be cost effective. Might be time to get creative and check out pistons for other brands. Something out there has to work with a little creative machining.Brian
That's what this thread was started to see if anyone already knew this info?Originally posted by blkfordsedan View PostI'm sure several places would custom make some, but I doubt it would be cost effective. Might be time to get creative and check out pistons for other brands. Something out there has to work with a little creative machining.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
I'm thinking of having stock ones cryo treated to resist wear.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
it's supposed to keep heat off the crown and IN the chamber for a more efficient use of the heat energy. the rings shouldn't see any real accumulation of heat if the oil system is in good working order and the rings are gapped properly.Originally posted by william View Postnot sure but would ceramic coating have any benefits ?? if you couldn't find forged
I know it doesn't make the piston its self stronger but it helps with wear keeping the heat off those rings might make them last longer
Denis, you should consider running another .005-.010" more ring gap in the first ring (the one that sees the most heat).Trees aren't kind to me...
