If they work, one disadvantage that I could see with using OEM spec B6T pistons would be a lower compression ratio. Right now, your used to ~9.2:1 compression. With the increased overlap of the FMS cam, that might be a deal killer.
B6 piston options
I'm kinda confused about the goal of this engine, were you going to turbo this or keep it n/a?2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Right now it is turbo, read my sig, the rings have worn to quickly and have blow by. I'm building another b6 to replace the one in my car so no down time.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
Tell ya what, ill take your old pistons off your hands. I'll pay for shipping...Originally posted by rbrown View PostI would love to up the compression of my b6t before I drop it in. 7.9 is too low.
Dennis
88 Dakota tow pig
Anyone else have any insight?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
rbrown: i was not suggesting 7.9 is a good ratio for a 1.6 or BP. Guys make good power with the stock pistons over 9:1 WITH TUNING. It was just an example for a different application where in my location we consider dropping static down to offset poor quality pump gas, or good quality low octane gas if you wanted to be more accurateLast edited by getnpsi; 04-17-2012, 10:59 AM.1993 GL 5 speed
Stock b6t pistons aren't forged, they are cast. Like others have suggested, forged pistons won't solve your ring issue unless you have some made with a lower and thicker top ring. JE will do all of this for you, PM me for the guy to talk to at JE, your looking at around 800 for a set. If I were you I'd use an OEM oversized replacement cast piston with federal mogul rings, file the top ring loose ( like arty said). Total seal works too, but they use federal mogul rings to make their rings (I go over to total seal to get my rings directly from them when I use total seal). Good luck!Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
The current issue with my rings is I was forced to use economy iron rings when I put my engine back together due to time restrictions and parts avalible. The held good for about a month. I obviously plan to run a premium ring this time. If I were to buy stock replacement cast pistons, would it be worth my time money to have them cryo treated or some type of coating applied to help withstand the heavy stress of daily 14psi?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Corky Bell knows what to do! :p2008 Kia Rio- new beater
yes and yes!!! especially the coatings!!! i recomend SwainTech.Originally posted by gauge_half_inch View PostIf I were to buy stock replacement cast pistons, would it be worth my time money to have them cryo treated or some type of coating applied to help withstand the heavy stress of daily 14psi?Trees aren't kind to me...
Yeah yeah....Originally posted by zoom zoom View PostCorky Bell knows what to do! :pIm not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
A properly tuned car with cast pistons will live just fine.Originally posted by gauge_half_inch View PostThe current issue with my rings is I was forced to use economy iron rings when I put my engine back together due to time restrictions and parts avalible. The held good for about a month. I obviously plan to run a premium ring this time. If I were to buy stock replacement cast pistons, would it be worth my time money to have them cryo treated or some type of coating applied to help withstand the heavy stress of daily 14psi?Rodney
1991 FI 5 Speed Aqua Blue
why is everyone so set on valve reliefs lining up? just don't skip a tooth on your timing belt.
The one thing you should ask yourself is how much money do you want to spend to do it properly? Rebuilding an engine is ALOT of cash when doing it properly. Don't expect to rebulid one for any less then $1200 for an OEM bulid.
My advice to you is find a low mile b6sohc engine or throw in a JDM miata one.
