Re: Weber adapter plate.
If your in a state that does emissions then you can't just remove the bulb... I think a lot of emissions places look for when you turn the car on the check engine light has to come on for a few seconds then goes off, so the way around that if you have that problem is find the wire that feeds the check engine light on the dash, cut it and tie it into the brake light on the dash because it does a a check on initial start up.
Sent from my LG-LS970 using Tapatalk 2
