Just get an EGR gasket and a small piece of 1/4" aluminum plate. Trace the gasket, drill the holes, cut out the pattern and file it smooth, bolt it on with the gasket. Done.
Rocketman Carb Adapter
 Ok so SOT but where is best to purchase a kit or individual jets for my Progressive Weber? I tore into it this WE & it may be a knock off since nowhere on it does it say maid in Spain & I found a few of the jets installed had NO markings (yes I cleaned & checked thoroughly)?
 The adapters are $80 USD with shipping. I believe the Escort carb is from the early 80's - maybe someone with more experience with the Escort carb can chime in. A search may turn up some more info as well1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
 Rocketchips!
 Bolt-on Weber Carb Adapters!
 1983-85 carby Escorts were 1.6L. The other carby was the 1985-86 1.9L motor.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
 Is this on a Festiva ? And what year and model of Escort carb - stock jets ?Originally posted by zoe60 View PostI have one with an Escort carb on it and I love it! Replaced my 32/36. I've had both now and IMO, the Escort carb is far superior. Might be selling this Weber soon! Rocketman makes a fine product!
 Are you still selling the adapters? And, How can i order one?Originally posted by Rocketman View PostThe adapters are $80 USD with shipping. I believe the Escort carb is from the early 80's - maybe someone with more experience with the Escort carb can chime in. A search may turn up some more info as well
