Lots of things that really matter for a little more money, like where does the heat go from more power? How do you direct that additional heat away from the headgasket and the rings? How do you control combustion to produce more pressure on the piston without detonation? For this you spend well under the going rate for this technology.
A budget build can produce more power without a doubt but the result should not be flogged with impunity and expect it to hold up to performance use!
