I did a ton of research on boost with a Weber carb... Can't remember all of it now though... LOL. Why do you think the money goes down the drain with nitrous? It's actually not expensive... I added up the cost of turbo vs supercharger vs nitrous. Obviously the install cost on nitrous is wayyyy cheaper, then a bottle last you a long time on a festy because you can't jet the nitrous super high and the refills are only like 40 bucks... It's like filling a regular cars gas tank. If you used your nitrous a lot on the highway and to beat honduhhhs it should easily last a month or even 2 months. If you used it sparingly then you could easily get 3-4 months
Sent from my LG-LS970 using Tapatalk
I have done a fair amount of research on turbos, literally zip on nitrous. I originally planned on boosting the B8 in the '88.. if/when it ever gets finished. I shall look up more on nitrous tomorrow.. but the very, very, very minimum searching I've done so far just makes the setup look expensive for the initial system.
Fuel puddling in the intake is an issue, too I think.
