Questions about Rear turboing a B6 SOHC
  • #31
    I originally was going to use an msd retard module and an fmu. Went megasquirt instead. Best thing I could have done. Been daily driving it for a few years now, it's been reliable . Just wanted to say that it is not easy to set up but the ability to actually adjust fuel and timing is great. I'm running the stock fuel system and could easily get 9:1 afrs at 6 psi boost if I really wanted.
    Tim
    '97 Aspire ST, UltraViolet Blue, 37k miles - New Storage Queen
    '03 SVT Lightning, Dark Shadow Gray, 30k miles - Storage Queen 11 months/year
    '95 SVT Aspire B3T, Green Mica, 75k miles - DD
    '01 ZX-500R, Violet Pearl/Gray, 5400 miles - Storage Queen
    '89 Suzuki FA50 Bright Red - Lake Transportation
    Cardomain.com/id/aspiresvt
    Previous Vehicles
    '92 Festiva L "Sport" Green Mica
    '92 Festiva GL Blue Pearl
    '92 Capri XR2 Performance Red
    • #32
      i bought my ms2 from here it only took a weekend to put together if your just going to run fuel you could probably use a ms1 its a little cheaper it'll be allot better to be able to actually tune your fuel with a turbo you dont want to blow a head gasket from running to lean
      ms1 box : http://www.diyautotune.com/catalog/m...ase-p-108.html
      ms2 box : http://www.diyautotune.com/catalog/m...products_id=59
      88 L carb'ed (when up in flames of glory)(deceased) 4spd
      89 L carb'ed (died on the operating table (rust))(deceased) 5spd
      93 gl FI (sold) automagical
      89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
      88 L carbFI megasquirted zombie car
      • #33
        Originally posted by TorqueEffect View Post
        Yeah, just did an eBay search. They seem to be about $100. What ratio would be best? I plan to run about 8 or 10 psi of boost, nothing more to avoid throwing rods.
        The way Euro mentioned is the cheapest easiest.
        Just grab one of these
        http://www.ebay.com/itm/130973820227
        And put in an extra fuel pump. Here's a cheap one.
        http://www.ebay.com/itm/111670800623
        Then babababoost.
        • #34
          Yeah don't bother with a wideband, you don't need to know if you're lean or rich in real time..
          91GL BP/F3A with boost
          • #35
            That is true about the wideband it takes a real long time to melt an aluminum piston or burn a valve.
            Tim
            Previous Vehicles
            • #36
              People used to tune boosted cars without widebands. EGT is cheaper and works too.
              • #37
                It's a lot of convenience and insurance for $150 though.
                • #38
                  Wideband will let you know much quicker if you have a problem with fuel delivery . I have both. The autometer egt is a much slower responding gauge. I agree that tuning by Temps could work why not use newer methods that cost marginally more. A 150 dollar wide band isn't that much considering an egt can run you 70 bucks. You want to tune it for reliabity. Not just power.
                  Tim
                  Previous Vehicles
                  • #39
                    Golly for more accuracy they should narrow the band..
                    • #40
                      Like ^
                      Tim
                      Previous Vehicles
                      • #41
                        Originally posted by sketchman View Post
                        Then babababoost.
                        +1
