So I'm currently swapping a bp/g with plans of a turbo after I get all the bugs worked out but being as I just swapped the bp and didn't rebuild it ( auto engine with evidence of mainly very low rpm usage and minimal wear) still had 187k im gonna run low boost like 5psi but my plans of a high hp highway monster doesn't exactly fit my current budget so I got impatient and pulled my worn out but a sweetheart b3 and began swapping now I can buy another bp and start with machining I got quoted $800 for a clean up valve job and balancing now ill probably be add to 1400 for porting and polishing and bigger valves? Maybe I can find a aftermarket high hp head I want to aim for the nastiest bp thatll last 100k I know some will say do a b6t and rpm hp but I also want good torque im think the flying miata 2.1 stroker with the super h beams expensive but hey it takes care of a extremely strong crank and rods with a rev limit of 7k (with very well balancing) I think will be very safe and 600cc injectors also found a high performance rebuild kit weisco pistons mls head gasket also cams? I'm want a lumpy aggressive cam (love the sounds at idle) but at the same time it still needs to be street saw maruha 264's were still alright for street but 44° of overlap it too aggressive and 272s are too aggressive? Don't know alot about cams honestly but happy to learn also turbocharging I love turbos anyway I kinda have my heart set on a compound turbo setup with a t3 and a gt3582r maybe 20 psi I mean itll still be a street car and I'm a pretty calm driver for the most Part but I like having fun too (like feeling the force of a festiva pulling you into the back seat) I'd like in the area of 350 hp with extreme reliability thoughts, comments, advice?
Reliable bp hp turbo build
Festiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
I will own a bpt cd-5 gtx clone one dayTags: None
When i build my 2nd festiva i plan to go high hp bp+t. I would like to see what others come up with here. My 2nd build is way off but its fun to think about it.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Same man haha I enjoy thinking this way too much but I figured get a plan downOriginally posted by mikemounlio View PostWhen i build my 2nd festiva i plan to go high hp bp+t. I would like to see what others come up with here. My 2nd build is way off but its fun to think about it.
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
I would highly recommend not doing sequential turbos, but consider trying super/turbo compoundsOriginally posted by Festiver View PostSo I'm currently swapping a bp/g with plans of a turbo after I get all the bugs worked out but being as I just swapped the bp and didn't rebuild it ( auto engine with evidence of mainly very low rpm usage and minimal wear) still had 187k im gonna run low boost like 5psi but my plans of a high hp highway monster doesn't exactly fit my current budget so I got impatient and pulled my worn out but a sweetheart b3 and began swapping now I can buy another bp and start with machining I got quoted $800 for a clean up valve job and balancing now ill probably be add to 1400 for porting and polishing and bigger valves? Maybe I can find a aftermarket high hp head I want to aim for the nastiest bp thatll last 100k I know some will say do a b6t and rpm hp but I also want good torque im think the flying miata 2.1 stroker with the super h beams expensive but hey it takes care of a extremely strong crank and rods with a rev limit of 7k (with very well balancing) I think will be very safe and 600cc injectors also found a high performance rebuild kit weisco pistons mls head gasket also cams? I'm want a lumpy aggressive cam (love the sounds at idle) but at the same time it still needs to be street saw maruha 264's were still alright for street but 44° of overlap it too aggressive and 272s are too aggressive? Don't know alot about cams honestly but happy to learn also turbocharging I love turbos anyway I kinda have my heart set on a compound turbo setup with a t3 and a gt3582r maybe 20 psi I mean itll still be a street car and I'm a pretty calm driver for the most Part but I like having fun too (like feeling the force of a festiva pulling you into the back seat) I'd like in the area of 350 hp with extreme reliability thoughts, comments, advice?
Please teach me haha I saw your dyno videoOriginally posted by Flyin4stroke View PostI made 374hp on 24 psi.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Hmm like a rotex and a gt3582r? Have the super do bottom end with the turbo to enter at the top? Or the t3 to do bottom end with a larger sc to handle top end I mean I'd love the have the massive gt3582r sitting over the trans open the hood and just see this monster turbo ready to inhale small childrenOriginally posted by bhearts View PostI would highly recommend not doing sequential turbos, but consider trying super/turbo compounds
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Yes, literally as small of a supercharger power band as possible, with its only goal of providing extra exhaust gas to spool the turbo with. So efficiency not even a worry. I'm thinking an Eaton charger. Rough estimate for you - 15psi from a supercharger at 1500 rpm should create 3x the exhaust gas compared to a no s.c.engineOriginally posted by Festiver View PostHmm like a rotex and a gt3582r? Have the super do bottom end with the turbo to enter at the top? Or the t3 to do bottom end with a larger sc to handle top end I mean I'd love the have the massive gt3582r sitting over the trans open the hood and just see this monster turbo ready to inhale small children
Huh I didn't even think about how itll multiply the exhaust gasses that's a really good idea another thing to ponder is awd? Maybe instead of gtx drive train do a Quattro setup from a audi TT 1.8t Quattro help send the power to the groundOriginally posted by bhearts View PostYes, literally as small of a supercharger power band as possible, with its only goal of providing extra exhaust gas to spool the turbo with. So efficiency not even a worry. I'm thinking an Eaton charger. Rough estimate for you - 15psi from a supercharger at 1500 rpm should create 3x the exhaust gas compared to a no s.c.engine
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
I think you'd have better luck moving the engine forward more than 2 inches. Awd is just going to weigh you downOriginally posted by Festiver View PostHuh I didn't even think about how itll multiply the exhaust gasses that's a really good idea another thing to ponder is awd? Maybe instead of gtx drive train do a Quattro setup from a audi TT 1.8t Quattro help send the power to the ground
Really? Forward mounting does that muchOriginally posted by bhearts View PostI think you'd have better luck moving the engine forward more than 2 inches. Awd is just going to weigh you down
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
A 200hp festiva with the engine moved 2" forward, combined with a well dialed suspension setup, and the car can out pull almost anything on the road and out corner almost anything on a race track. No need for AWD or twin turbos or sequential chargers. All this is just asking for trouble. Build a simple, but we'll designed car and you'll never regret it.Originally posted by Festiver View PostReally? Forward mounting does that much
Sent from my XT1585 using TapatalkDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Wow didn't know it was that drastic I know Charlie said 165s were the optimum width tires but will forward mounting really help them with 300+ lbs of torqueOriginally posted by bhearts View PostThe number is 100 pounds of perceived wheel weight per inch forward.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
