I know its pointless but it is fun.
Reliable bp hp turbo build
Cool thing about super turbo with an Eaton is that you could choose your spool response by setting the boost on the supercharger with the bypass valve and actuator. It could run 15psi, but let's say you're only feeling like 5psi today for easier driving, totally doable.Originally posted by Festiver View PostOh yeah no I have no intention of doing this soon I'm gonna run like 5 psi in a stock bp+T for a while this is just kinda a feeler post for a build plan haha but ok so 165 is about maximum for acceleration I was thinking at higher speed like highway accelerating maybe you could put 350 to the ground (keep in mind I'm just a kid who reads about builds alot not much actual experience) but I gotta be honest if if I have the ability to get wheelspin just from accelerating at 60+ thatd make me smile haha not a constant thing just the occasional little high-speed burnout haha (like I said still a kid) but it's just neat to think about but the sounds a 82 mm turbo will make at 20-25 psi now that's beautiful and I'm loving bhearts idea of a small Eaton supercharger + the 82mm turbo (I know very excessive but hey this is a no expense spared mental build)
Sent from my XT1585 using Tapatalk
The best builds are hahaOriginally posted by Flyin4stroke View PostI know its pointless but it is fun.
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Really? I didn't know sc's were adjustable like that wait are you talking twin screw or centrifugal thatd be awesome can you run a twin screw on adjustable boost besides under drive pullysOriginally posted by bhearts View PostCool thing about super turbo with an Eaton is that you could choose your spool response by setting the boost on the supercharger with the bypass valve and actuator. It could run 15psi, but let's say you're only feeling like 5psi today for easier driving, totally doable.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Roots. Like a m90,62Originally posted by Festiver View PostReally? I didn't know sc's were adjustable like that wait are you talking twin screw or centrifugal thatd be awesome can you run a twin screw on adjustable boost besides under drive pullys
If a m90 makes 8psi on a 3.8l engine, it should make just over double that on a 1.8l if you keep the blower speed gearing the same. And then you could adjust it anywhere from a little boost to all the boost with a wastegate actuator.
How would you adjust with it being direct to the manifold?Originally posted by bhearts View PostRoots. Like a m90,62
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Huh I didn't even know root styled had something like that that's way awesomeOriginally posted by bhearts View Post
This bish
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
If the bp has a similar exhaust cfm as the vw 1.8t 20v then the 82 mm will come alive and very violent at 5k-5500Originally posted by bhearts View PostThat way you could pretty much select the rpm you want turbo boost at
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
You think so? I think I'd be awesome accelerating kinda meh not very fast not very slow then turbo wakes up forces you into the seat hard very suddenly personally I'd prefer it at 3k rpm which from the sounds of it the supercharger will make it a much smoother transition but also alot more bottom endOriginally posted by bhearts View PostThat would be a terrible driving experience
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
If anything over 250hp is useless, you might as well go all out with a super turbo. I'd rather have too much turbo turned down, than too little turbo turned upOriginally posted by Festiver View PostYou think so? I think I'd be awesome accelerating kinda meh not very fast not very slow then turbo wakes up forces you into the seat hard very suddenly personally I'd prefer it at 3k rpm which from the sounds of it the supercharger will make it a much smoother transition but also alot more bottom end
True a 82 mm will have a a ton of flow so 15 psi will probably get you over 250whp and useless depends on definition haha wheelspin is still fun for me to an extent tires get expensive hahaOriginally posted by bhearts View PostIf anything over 250hp is useless, you might as well go all out with a super turbo. I'd rather have too much turbo turned down, than too little turbo turned up
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
But, you got to be careful when picking out the right turbo. If you run too low of boost you can get surging which is when the impeller speed isn't high enough and the pressurized air tries to go backwards through it. So it's unrealistic to want a 600hp turbo to run at 250hp pressure levelsOriginally posted by Festiver View PostTrue a 82 mm will have a a ton of flow so 15 psi will probably get you over 250whp and useless depends on definition haha wheelspin is still fun for me to an extent tires get expensive haha
Sent from my SM-G900V using TapatalkLast edited by bhearts; 07-25-2016, 11:45 PM.
