Reliable bp hp turbo build
  • #31
    I know its pointless but it is fun.
    1989 Ford Mustang GT 5.slow
    1996 Ford F-150
    • #32
      Originally posted by Festiver View Post
      Oh yeah no I have no intention of doing this soon I'm gonna run like 5 psi in a stock bp+T for a while this is just kinda a feeler post for a build plan haha but ok so 165 is about maximum for acceleration I was thinking at higher speed like highway accelerating maybe you could put 350 to the ground (keep in mind I'm just a kid who reads about builds alot not much actual experience) but I gotta be honest if if I have the ability to get wheelspin just from accelerating at 60+ thatd make me smile haha not a constant thing just the occasional little high-speed burnout haha (like I said still a kid) but it's just neat to think about but the sounds a 82 mm turbo will make at 20-25 psi now that's beautiful and I'm loving bhearts idea of a small Eaton supercharger + the 82mm turbo (I know very excessive but hey this is a no expense spared mental build)
      Sent from my XT1585 using Tapatalk
      Cool thing about super turbo with an Eaton is that you could choose your spool response by setting the boost on the supercharger with the bypass valve and actuator. It could run 15psi, but let's say you're only feeling like 5psi today for easier driving, totally doable.
      • #33
        The best builds are haha
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        Aspire brake swapped
        stripped and sold due to rust
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
        • #34
          Really? I didn't know sc's were adjustable like that wait are you talking twin screw or centrifugal thatd be awesome can you run a twin screw on adjustable boost besides under drive pullys
          Festiver
          93 L find/5 speed
          BP/g15mr swapped
          89 festie
          rustful
          93 festie
          advanced suspension
          kai/skeeter camber
          b3t/g15mr
          • #35
            Roots. Like a m90,62
            If a m90 makes 8psi on a 3.8l engine, it should make just over double that on a 1.8l if you keep the blower speed gearing the same. And then you could adjust it anywhere from a little boost to all the boost with a wastegate actuator.
            • #36
              How would you adjust with it being direct to the manifold?
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
              • #37
                This bish
                • #38
                  This bish
                  Huh I didn't even know root styled had something like that that's way awesome
                  Festiver
                  93 L find/5 speed
                  BP/g15mr swapped
                  89 festie
                  rustful
                  93 festie
                  advanced suspension
                  kai/skeeter camber
                  b3t/g15mr
                  • #39
                    That way you could pretty much select the rpm you want turbo boost at
                    • #40
                      If the bp has a similar exhaust cfm as the vw 1.8t 20v then the 82 mm will come alive and very violent at 5k-5500
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • #41
                        That would be a terrible driving experience
                        • #42
                          You think so? I think I'd be awesome accelerating kinda meh not very fast not very slow then turbo wakes up forces you into the seat hard very suddenly personally I'd prefer it at 3k rpm which from the sounds of it the supercharger will make it a much smoother transition but also alot more bottom end
                          Festiver
                          93 L find/5 speed
                          BP/g15mr swapped
                          89 festie
                          rustful
                          93 festie
                          advanced suspension
                          kai/skeeter camber
                          b3t/g15mr
                          • #43
                            If anything over 250hp is useless, you might as well go all out with a super turbo. I'd rather have too much turbo turned down, than too little turbo turned up
                            • #44
                              True a 82 mm will have a a ton of flow so 15 psi will probably get you over 250whp and useless depends on definition haha wheelspin is still fun for me to an extent tires get expensive haha
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • #45
                                But, you got to be careful when picking out the right turbo. If you run too low of boost you can get surging which is when the impeller speed isn't high enough and the pressurized air tries to go backwards through it. So it's unrealistic to want a 600hp turbo to run at 250hp pressure levels
