Green Sales Company shows one in stock.
Quantity PartNumber Update Basic Description
1 E8BZ9E731A 11/18/2010 SENSOR ASY SPD CTL
I will remove my speedometer gear and try screwing this sensor in between the speedometer gear and the speedometer cable. If it works, I will post a picture for you after I try spinning the gear to make sure the speedometer responds.
Whatever way you slice it, The pickup lead must go back to the cruise computer which should be located under the dash.
The magnetic pickup on the speedo cable is the most accurate way of determining vehicle speed. As the sleeve magnet passes the mini magnets located in the sensor hub, a pulse is generated in the current. The pulse frequency is directly related to the speed of the vehicle.
