The Mazda RX-7 cruise control on/off dash switch has the following four wire colors:
Black Tan
Brown/Black stripe Red/Green stripe
The only continuity I detected is between the black ground wire and the tan wire, when the switch is activated. I must test further. I am unsure if this is an illuminated switch or not. I am only guessing, but I believe when you set speed on the stalk, power goes back to the switch through the red/green wire for illumination.
Here is a link to the Rostra cruise kits.
					Black Tan
