:hello1:
Got a little ahead of myself but it is ok
First remove old int light
Then cut away a small amount of your headliner
Use your new map light for dimensions DON'T cut out too much ---- less is better in this case
The two screws are the new holes for the light plus you need to use one of the old holes also.
As for wiring it can be done wrong this is what I did and had to swap wires around.
Here is the correct way
When you get your map light leave enough wire to make connections about 3''.
Wire the white/red stripe from car to blue/red stripe from light then
wire red/blue stripe from car to red/white stripe from light.
Then install with 3 screws.
Install covers
Presto you have int lights with map lights.
Pretty simple mod, and comes in handy alot.
Enjoy
Install covers
Enjoy
