Brake upgrade and hydraulic clutch
    Well the manual Capri pedal assemblies are very close between the two, the bolt pattern for the Capri master cylinder is the same as where the cable bolts to the firewall. You may only need to drill the pedal arm and add an actuator rod. I have both pedal assemblies here if you really wanted I could pull them out and take pictures. I don't think the Festy bolt pattern is the same though, now that I think of it.
    Theoretically you wouldn't have to really swap anything at all
    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
    Rocketchips!
    Bolt-on Weber Carb Adapters!
      please, the photos for reference would be really ideal.. out of curiosity, could i get a comparitive shot of the festiva and capri pedal setups so i could easily tell the differences and debate with myself as to which of the two pedal sets i'd use.
      thanks rocketman.
      Avg Economy:
      Highway - 7.32L/100km
      City - yet to be determined.
        Originally posted by gorgonheimer View Post
        Looks like this is better than the clutch master through the clutch cable hole. You will have full pedal travel not two inches like mine.
        what is the cause of the 2" of travel?
        The next two questions are dependant on the answer from the first question.
        wouldn't there be just a simple matter of bleeding the clutch to "recover" the two inches?
        could you modify the hydralic shaft to "compensate" for the two inches of travel?
        Avg Economy:
          Travel is a result of pedal geometry. The master cylinder is mounted in clutch cable hole. This is down from where it needs to be making the lever, or clutch pedal shorter.
          Neil
          Jesus loves me. This I know.
          93 L track prep in progress
          88? Parts car-sold
          91 L B6-me f25mr-soon to be ???
          86 b2000- pisses of HOA-sold
          1997 k1500 suburban- kid hauler/GAS hog
            DEAD THREAD!... But is this the best option for a hydro clutch? I have an f out of a GT and damn if its not cheaper to run that then find a new cable setup.
            Lil' Red Rocket '93 Festiva: Stock, A/C, Rear wiper, Rear defrost, Alloys, Power mirrors, White Tach,Super tail action (factory spoiler)
            Frogstiva '92 Festiva: Just bought a HOT MESS. BP swap with E trans (not done), Built Red from factory spray bombed black with stripes, Aspire swap, Escort GT Master Cylinder, found frogs in vehicle, hence Frogstiva, pulling all good parts for Lil' Red Rocket.
            1.7 PN Diesel and trans, waiting for good shell.
