My festiva with 15 inch rim 195/50R15
wheel/tire/suspension fitment thread
what;s the front lip?Trees aren't kind to me...
Originally posted by festyfreak39 View Postthat green festiva with the fender flares is absolutley bad @$$, where did you get those flares!!!!!!!!!!!!!!!!
this is mine, cant remember the sizes of the tires, fitment is nothing to boast about though. Silver wheels are from a mitsu mirage, and the red wheels are my current setup.
No pictures (haven't figured out how to load them) but info is:
4.5" x 13" stock Geo Metro rims
155 x 60 x 13 tires (exact dimensional size of 155 x 12 Festiva oem)
Gr 2 shocks
Standard springs & brakes & fenders
Tons of clearance all around
Very simple tire/wheel swap for going from 12" to 13"
^ i have this exact setup on my DDBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Guessing these would be a no go...
14x7 +8 offset. They are older Celica Supra Wheels.
I think width and offset will make them impossible to fit without major modifications.
i figgured i would update my setup and add some pics
15x6.5
38 offset
195/50/50
APEX front coilovers, the rears are just ebay springs over factory struts...
no spacers
i cut the rear spring pearch and rolled the inner lip of the rear fender a tiny bit to clear the outside of the tire...
front coils.
Mike, AKA the sasquatch
sasquatch, your car has a real nice stance. Were did you get your front coilovers at?Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
i got them from a guy for free.... he said they are from a mk2 or mk3 golf... they fit great, and ride SOOOO much better than the ebay springs on factory struts... well worth the drive to go pick them up lol....
sasquatch...did you have to do any modifications to get them to fit?
aspire swap and vw coilovers on the front, thats it for the front... the rear i have also done the aspire swap but still have the factory struts (festiva i think... not aspire... same thing tho lol...) and ebay springs over top of them... then i cut about 1/2 an inch off the perch to clear the tire and rolled the inside of the fender to clear the outside of the tire... thats it... everything else is stock....
Originally posted by sasquatch View Postaspire swap and vw coilovers on the front, thats it for the front... the rear i have also done the aspire swap but still have the factory struts (festiva i think... not aspire... same thing tho lol...) and ebay springs over top of them... then i cut about 1/2 an inch off the perch to clear the tire and rolled the inside of the fender to clear the outside of the tire... thats it... everything else is stock....
they are from a civic "kit" but allmost all "kits" are the same on ebay.... and IIRC they are 7 inch long...
