Coil-overs from mk2-3 golf on festiva write up (pics)
  • Coil-overs from mk2-3 golf on festiva write up (pics)
    Ok so i decided i should have a little write up on installing coilovers on the festiva.
    Coil-overs:
    Rokkor coil-overs for a mk2-3 golf $338 cdn
    380 (Front) 300 (Rear)
    Follow rokkortuning on eBay. Buying, Selling, Collecting on eBay has never been more exciting!
    They are the same as racelands but a bit cheaper and with a higher spring rate.
    im still working on putting it together ill have info and more pics soon..
    BP Festiva on MS2 with gsxr itbs Woot!!!
    Looks good! What all work did you have to do to get them to fit? The only thing I could see was drilling out the bolt hole.
    :festiva::newb::festiva:
      ^ You shouldn't let your caliper just dangle like that, stretches the brake hose.. get some wire and hang it off the spring.
      -85' Nissan Sentra 5 spd.
        What's the spring diameter on those?
        Current cars:
          Those look really good! may have to go that route on the aspire. keep us posted
          Tim
          '97 Aspire ST, UltraViolet Blue, 37k miles - New Storage Queen
          '03 SVT Lightning, Dark Shadow Gray, 30k miles - Storage Queen 11 months/year
          '95 SVT Aspire B3T, Green Mica, 75k miles - DD
          '01 ZX-500R, Violet Pearl/Gray, 5400 miles - Storage Queen
          '89 Suzuki FA50 Bright Red - Lake Transportation
          Cardomain.com/id/aspiresvt
          Previous Vehicles
          '92 Festiva L "Sport" Green Mica
          '92 Festiva GL Blue Pearl
          '92 Capri XR2 Performance Red
            don't forget pics afterwards!!
            -Aspire brake swap COMPLETE!
              I had to drill out the bottom hole and on the top hat make the hole a bit bigger for the shaft.
              I have new lines going in so im not to concerned plus those are the festiva calipers aspire ones will be on soon.
              Ill let you know tomorrow.
              So far everything is going smooth i do need a brake hardware kit for the aspire stuff so if i get that tomorrow ill be done the front and post more pics. Also ill add all info for what i bought and did once im done.
                wow i want a set of those... ill have to check them out at the westiva meet.. im tired of how over-sprung mine are... and grocerygetter had mk3 golf stuff in his car and he said he liked it alot...
                Mike, AKA the sasquatch
                  you should make a plate to where you know where to drill and sell them on here.
                  Current cars:
                    Here are some new pics the front is in and is in need of a wheel alignment badly lol.
                      whats the spring rate on those? also any idea how stiff the valving is on it? (i dont know what they measure that in...)
                        380 (Front) 300 (Rear) they seem pretty stiff i should have the rear done tomorrow then ill let you know about ride if its nice out.
                          any idea what the helper spring is rated to? im hoping that little spring will take most o the small bumps and make it a smooth ride, then when you start getting in to the hard corners then the big spring will take over....
                            Helper springs are only there to prevent the big spring from getting unseated.
                            Oscar
                              well its all done just a few minor things to do and ill have the car good to go.
