Originally posted by Pineapplegti
Originally posted by DON SVO
I found that the noise that you will hear in the rear will be from the top of the shock. The diameter is a tiny bit smaller so it rattles a bit nothing that bad. As for the bottom bolts they fit perfectly no chance for them to be causing all the noise i think.
The fronts took some time to get to right..
