Ok I've read through the lot thanks Charlie and everyone for the thread! Will start putting a parts list together for my UK based pride!
Advanced Suspension Mods
This is a sticky topic.
Look at my thread I went throught all this and them redid it in a way that was straight to the point. I have the full how to with shopping list and bolt for bolt pictures on what to do. I got all my info from this page all credit goes to this OP. I just took out all the chatter from the page.Originally posted by Bdonkin88 View PostOk I've read through the lot thanks Charlie and everyone for the thread! Will start putting a parts list together for my UK based pride!
Anyway check it out.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
advanceDynamix your setup is nice and low. i recently purchase a 92 and was wanting to know if i can use this setup to go as just as low in your pic: mk2 Front struts/ 150lbs 12" springs & 93vw cabriolet rear shocks/ 120 lbs 10" springs?
I'm trying to go extreme low with decent drivability. it will not see track until i swap a BP down the road.
For extreme low you'll want 120lb front springs and 105lb rear.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Do you remember the demensions on those spring hats I can make them quick next week but I don't have the springs to know lolOriginally posted by Advancedynamix View PostHere is one of the rear spring hats that I made. The kit came with some, but I wanted lower profile ones that mated up with the stock shock bushings better. You could use an assortment of thick washers from the hardware store to do the same thing.
Here are the finished shocks
and installed
And notice the clearance! They offer 4 real inches of suspension adjustment without sacrificing tire room!
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Originally posted by Festiver View PostDo you remember the demensions on those spring hats I can make them quick next week but I don't have the springs to know lol
Sent from my XT1585 using TapatalkHad to dig back a little bit, but the answer was right here in this thread.Originally posted by cliferton View Postthese are the rear top hats for this suspension setup. the 7mm one is the one that Charlie did and I drew based off his measurements, and the 25.4mm is the one that I did after talking with him on spring location. I believe he used steel that was hard anodized for the 7mm while the 25.4mm was made from t6 6061 and was not coated. The centering step diameter may need to be modified very slightly depending on spring rate. I believe I turned mine slightly smaller than the print and the model show. I will measure them as soon as I get the rear apart again. Just measure the true I.D. of your spring before you make them or have them made.
Here is the dropbox link to blueprints and solid model of the hats. I saved them as a generic .IGES If you want a more specific file type lmk.
My steel hats were powder coated and the aluminum hats were hard anodized. I don't think steel can be hard anodized. I have made some which were zinc coated though, which is similar to hard anodize.Last edited by Advancedynamix; 01-08-2017, 11:59 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I have a guy that was gunna make me some like I got off ebay but there much thicker.
Is there an advantage to them being thin other than the car sitting a half inch lower?
Here's what the one I bought looks like.
Sent from my SAMSUNG-SM-G900A using TapatalkLast edited by william; 01-08-2017, 12:19 PM.
The thin ones were my early design for the Festiva/Aspire KYB shocks with shortened shafts. The thick ones work better on the MK1 VW KYB shocks. That's the latest design.Originally posted by william View PostI have a guy that was gunna make me some like I got off ebay but there much thicker.
Sent from my SAMSUNG-SM-G900A using TapatalkDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Oh didn't even see it thank you so much thoughOriginally posted by Advancedynamix View PostHad to dig back a little bit, but the answer was right here in this thread.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
"Top of the thread" is a little ambiguous, but if you mean where the last two nuts retain the upper washer;
16 inches compressed / 24-3/16 inches extended, approximately, used a tape measure.Last edited by Dragonhealer; 01-17-2017, 08:10 AM.No car too fast !
Wonderfull! Can you shoot me the same dimensions off of the Demio shock? Am looking for an up grade for the 2012 Mazda2.Originally posted by reddragon View PostCheers mate, it gives me a base to work off - I'm messing around with struts off a '99 Demio, will see if I can modify them to similar dimensions.No car too fast !
Compressed 480mmOriginally posted by Dragonhealer View PostWonderfull! Can you shoot me the same dimensions off of the Demio shock? Am looking for an up grade for the 2012 Mazda2.
Extended 685mm
Strut diameter 38mm
Thats from centre of lower mount, to end of shaft. So take off 30mm, and that should be about where top nuts retain upper washer.
I'm not much good at converting mm back to inches, I should get one of those tape measures that has both!Last edited by reddragon; 01-17-2017, 11:43 PM.
