The eBay coilovers do work better than any of the OE replacement struts. They are shorter, and the valving is better matched. I didn't try those Bilsteins, but I made a set of coilovers from some Bilstein sport struts for a mk3 Cabrio. They were too stiff for a Festy. I sold them to AZGTX for his 323 gtx and I went back to the cheap eBay coilovers.
I've tested Boge, and Sachs VW mk2 OE fitment struts as well. None of them perform nearly as well as the the cheap coilovers. I also have Wietech and bilstein pss coilovers that I've adapted to fit a festiva. I've tested a lot of shocks. I put 250 track miles on a new set over the weekend.
Also, you can replace the inserts in those coilovers down the road with bilstein, koni or Tokico inserts if you want. They are serviceable. The first set I built have well over 100k miles on them, with well over 70k track miles and they are still going strong.
