Originally posted by russian
It had disk brakes, but the hub was the other way around - the axle stub is spinning with wheel, so it would not mount to our axle stub. Another funny thing - that brake rotor is both a rotor (there is a caliper - used for street braking) and a drum (the drum is used as e-brake), which means it has more offset because of the drum section. Seems like a bit of over-engineering.There is still a little hope - OReilly shows different part number and different picture for previous generation Galant hub (like 89 and 92) - this one seems to be for axle stub on the suspension.
