14x5.5
323 or EGT, one is bolt in, the other requires 2 wires and lower the front of the crossmember to rotate the engine off the firewall and a no weld passenger mount. both can use the factory trans without issue though the BP needs a gentler touch to keep the trans intact (roll on the throttle, no slamming gears). use their respective ECUs and VAFs and off you go.Trees aren't kind to me...
I may have to track these down.Originally posted by FestYboy View Post323 or EGT, one is bolt in, the other requires 2 wires and lower the front of the crossmember to rotate the engine off the firewall and a no weld passenger mount. both can use the factory trans without issue though the BP needs a gentler touch to keep the trans intact (roll on the throttle, no slamming gears). use their respective ECUs and VAFs and off you go.
-JamesEst. 1989 "Bringing laughter and festiva awesomeness to the world since birth" banana time
