14x5.5
323 or EGT, one is bolt in, the other requires 2 wires and lower the front of the crossmember to rotate the engine off the firewall and a no weld passenger mount. both can use the factory trans without issue though the BP needs a gentler touch to keep the trans intact (roll on the throttle, no slamming gears). use their respective ECUs and VAFs and off you go.Trees aren't kind to me...
Originally posted by FestYboy View Post323 or EGT, one is bolt in, the other requires 2 wires and lower the front of the crossmember to rotate the engine off the firewall and a no weld passenger mount. both can use the factory trans without issue though the BP needs a gentler touch to keep the trans intact (roll on the throttle, no slamming gears). use their respective ECUs and VAFs and off you go.
-JamesEst. 1989 "Bringing laughter and festiva awesomeness to the world since birth" banana time
