I used the Afco sleeves on my first set. They offer a 7" long sleeve too iirc. That's a nice option to have.
Ultimate Street suspension guide
This is a sticky topic.
The coilovers from hot tunning on ebay are now a bit different. I like them much better now. The lower body is much simpler and heavier duty. The mounting brackets that the bolts go through is now flat and much stronger looking.
If you look back at my original holes i messed them up big time. I was a bit on the drunk side. I have since found out its best to slot the lower hole up a bit (1/4"ish) and the upper hole inward a bit (1/8"ish). This will do 2 things. #1 it will lower the strut on the knuckle by the (1/4"ish) and #2 it will allow you to add in the neg camber.
One issue with the new design is that the upper corner of the mounting tab is quite square. It makes the corner stick out more the i would like. I am running 13" rims and i will have to use a small spacer to clear the strut mounting tab.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
20170625_084620.jpgOriginally posted by greywolf200 View PostPics please.
I havr not swapped my springs yet but here is the new coilovers. Also u can sre how i put tape on the body. This allows me to cut only the areas i want to.u can use paint or whatrver u want but for me the tape works best1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
must be quite a recent change, i grabbed a set around 2 weeks ago and they look like this.
hopefully i grabbed the right set lol. This was the link. http://www.ebay.com/itm/VOLKSWAGEN-V...53.m2749.l2649
Mine have a build date stamped on them of January of 2017. Looks like you got the last of the old batch maybe!?1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I can repost them maybe! Tomorrow1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Hit me up on Monday/Tuesday Mike, we are going to knock through it
- Korean Note 4 via Tapatalk -Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
Coilover question
Does this number code mean it's a 150# spring? Is this the spring I'll use for my ultimate suspension setup once I purchase the mk2 struts?Attached Files1991 Beastiva L BP autoX'er
I'm not sure if it means 150LB or maybe 150kg or something, but it is way too short. You want minimum 10" preferably 12" springs in the front.~Nate
Current cars:
FOTY 2008 winner!
Pictures are fixed! Thread has also been stickied for future reference, it deserves it.Will Samet
How to find me:
