Ultimate Street suspension guide
This is a sticky topic.
  • I used the Afco sleeves on my first set. They offer a 7" long sleeve too iirc. That's a nice option to have.
    • The coilovers from hot tunning on ebay are now a bit different. I like them much better now. The lower body is much simpler and heavier duty. The mounting brackets that the bolts go through is now flat and much stronger looking.
      If you look back at my original holes i messed them up big time. I was a bit on the drunk side. I have since found out its best to slot the lower hole up a bit (1/4"ish) and the upper hole inward a bit (1/8"ish). This will do 2 things. #1 it will lower the strut on the knuckle by the (1/4"ish) and #2 it will allow you to add in the neg camber.
      One issue with the new design is that the upper corner of the mounting tab is quite square. It makes the corner stick out more the i would like. I am running 13" rims and i will have to use a small spacer to clear the strut mounting tab.
      19?? 150$ burnout car SOLD
      1991 (STRESS RELIEF)SOLD
      • Pics please.
        Jack Byrd,
        1991 Capri
        1988 Festiva LX, 240K
        1970 Chev C10
        1977 Airstream Argosy MH
        • Originally posted by greywolf200 View Post
          Pics please.
          I havr not swapped my springs yet but here is the new coilovers. Also u can sre how i put tape on the body. This allows me to cut only the areas i want to.u can use paint or whatrver u want but for me the tape works best
          • must be quite a recent change, i grabbed a set around 2 weeks ago and they look like this.
            hopefully i grabbed the right set lol. This was the link. http://www.ebay.com/itm/VOLKSWAGEN-V...53.m2749.l2649
            • Mine have a build date stamped on them of January of 2017. Looks like you got the last of the old batch maybe!?
              • Very nice guys, I would really like to do this so I can lower this baby. Gotta do some work on my Capri first.
                Thanks again.
                Jack Byrd,
                1991 Capri
                1970 Chev C10
                • Is this thread going to get its pictures redone?
                  • I can repost them maybe! Tomorrow
                    • Hit me up on Monday/Tuesday Mike, we are going to knock through it
                      - Korean Note 4 via Tapatalk -
                      Will Samet
                      How to find me:
                      Feel free to PM me anytime!
                      Instagram/Twitter: @WILLSAMET
                      • Coilover question
                        Does this number code mean it's a 150# spring? Is this the spring I'll use for my ultimate suspension setup once I purchase the mk2 struts?
                        1991 Beastiva L BP autoX'er
                        • I'm not sure if it means 150LB or maybe 150kg or something, but it is way too short. You want minimum 10" preferably 12" springs in the front.
                          ~Nate
                          Current cars:
                          FOTY 2008 winner!
                          • Ahh gotcha, I thought it looked short compared to the 12"ers in the original post
                            • Pictures are fixed! Thread has also been stickied for future reference, it deserves it.
                              Will Samet
                              How to find me:
                              • Yay the pictures are back, i'm glad it's finally stickied! Will be very useful for new festiva owners.
                                Dark blue '91 B6t + E series
                                Something new breaks every day
