Run -3 all the time. As long as your toe is zeroed, you won't notice tire wear problems and you'll get much better ride stability and wet weather traction in the rear. It also helps with fuel mileage. I've been running lots of negative camber on these cars for years now and have yet to see a problem with it. I'm at around -4 degrees now!
Where do I set my spring nut height to install
How do I know where to put my spring nut for install. Not Pedro ride height, not off road either
