Put it on the car as is. Let the suspension free hang. The spring needs to be under tension even if the tires leave the ground. Once all under tension you can adjust even more to get more preload and a bit more ride height. But that's about it for my abilty. I put me so I had tension. All around. Then adjusted them both the same amount up just to make sure all was the same.
Sent from my SM-N910V using Tapatalk
